Old 07-08-2020, 10:26 AM
spdbrake spdbrake is offline
A tip we use for pulling lip seals on turbine engines is to drill the seal in the center of the metal rim with a #40 bit. We use drillstops to prevent dinging the underlying flange. Thread a drywall screw (hardened steel) into the seal and pryout with pair of Diagonal cutter pliers.
https://www.browntool.com/Listview/t...ch=drill+stops
https://www.browntool.com/Listview/t...9/Default.aspx
