Old 07-09-2020, 04:56 AM
joyridin''s Avatar
joyridin' joyridin' is offline
You can buy a VSS sensor from Autometer IIRC that hooks to a cable and gives you a VSS signal, which is what you need to run the speedo. I think Autometer also sells a GPS unit that will give you a VSS signal. Here is the link if it will work with your speedo:
https://www.autometer.com/blog/your-...ions-answered/
