The clamping parts should be made of 2" OD material and have pieces of rubber to install between the clamp and the 1 1/2" roll bar tubing make up the difference and give a non slip fit. the. If the clamping brackets are 2' OD, you got it covered. the spacing of the two roll bar legs is adjustable with the shiny tube in the back and the all thread. You have to cut that cross tube so when under tension the end clamps with the eye bolts are held facing forward. reach me at
mikes427@net-venture.com
I'll be with you shortly.
