  #24 (permalink)
Old 07-17-2020, 03:17 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
If you do have a 4150 double pumper, close the primary side to make the transfer slot a "square", and then open the secondary side to about equal by viewing with light, (carb removed from engine).
Refit carb, DO NOT touch the primary side for speed adjustment.
Use the secondary speed screw for idle speed.
Do not drill holes, no need for that old trick.
Gary
Gary
