Old 07-20-2020, 10:59 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Checkout mechman.comthey manufacture for a lot of the private label companies, call them and talk to them, tell them what you need and they tend to deliver just that. If you need a V-belt pulley let them know and it will come with that from them. Just make sure it is a G-3, You will need a larger main fuse for your system as these are HIGH output systems, at 1800 engine RPM mine puts out 174 amps, NO they are not cheap but I can run 2 16" fans with no trouble or major drop off of voltage.
Bill K
