Old 07-22-2020, 12:12 PM
Whodeeny Whodeeny is offline
Cobra Make, Engine: ERA 427
Default Small Diameter Water Pump Pulley from ACE
Acton Custom Enterprises sells a small diameter water pump pulley for FEs that will spin the water pump faster. Has anybody installed this on their FE? The reason I am asking is that I thought this might cause the radiator cooling fan on my car to run less. I have a ERA with a 427 big block engine and the heavy duty cooling system. I do not have the small fans that are typically mounted in front of the radiator. I have street car with the grill splitter installed so those small fans wouldn't fit. The cooling system on the car actually works quite well. My only complaint is that the cooling fan is noisy when it runs and I thought this might cause it run less. Any comments or recommendations? Thanks.
Here is a link the pulley -
https://actoncobra.com/index.php?mai...lley&x=15&y=10
BD
