Old 07-23-2020, 08:56 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is online now
Originally Posted by Gun Doc View Post
Not bad, but as a former aircraft technical inspector, I would had to have failed this particular safety. The initial loop though the bottom fastener should have been at the bottom of the bolt head - The two sections of wire should not touch. Also 6-8 twists per inch is what you are looking for with about a 1/2 " "pigtail" at the end that should be bent back into the bolt head. This keeps it from snagging on things, like your skin! All in all not a bad attempt and a good way to keep things tight. Did you use safety wire pilers, or was this done by hand?
I think I see. But will this version be any less effective?
Tony
CSX4005LA
