The manifold problem is solved in one of two ways, first thing you should do is determine how much hood clearance your carb is going to have. Clearance determined, you can add a tapered spacer, like 1/4" to 1/16th in or what ever combination to give you a level carb. The other alternative is to have the manifold milled, so as to give the same results, a level carb. I would suggest you add some angle to the engine, if hood clearance is available because one thing you have not mentioned is
OIL DRAIN BACK. The level head will give you, even with front and rear drain backs
puddling in the head.
Bill K
