You need to decide if you want “original” or a hot rod that looks like a Cobra. That answer will exclude some makes and push you towards others. It also helps with engine choice.
ie - ERA will be close to original and 427 cars would typically have FE engines. Backdraft is more of a hot rod modern take on the Cobra and typically has a Windsor striker or Coyote.
John
Both good but completely different.
