Thread: heat cycles
Old 07-28-2020, 11:22 PM
Michael C Henry Michael C Henry is offline
Cobra Make, Engine: Everett Morrision FE 427 so 2-4s
If you watch NASCAR , a lot of little things you never considered, come into light. The teams are given 10 sets of tires (40) for a race. That's everything, practice ,qualifying, etc. They have a crew member that it is his job to takes the new mounted tires with the new tire sticker still in place (sticker) and wheels and make sets of 4 ( left right front and rear) out of all the tires that are compatible with the other mounted tires in the set. The crew will install a set of new sticker tires on the car and the driver will then put some hard laps on the tires and get some heat built up in the tires . The used tires are now called scuffs. The crew will take a number of tires out for practice runs for so many laps and bring the car in and change the tires. The used tires are now called scuffs. The new tires are called stickers. I found out that the tires get harder after each heat cycle. A set of used scuff tires will last longer than a set of new sticker tires., but may not stick ( cling) as well but that is the trade off. Every time they have the tires heated up during the race and they have a caution the tires cool off some and change again.
Mike H
