When I first started tuning my engine, I had a stumble when accelerating from low rpms. No amount of carb tuning (mostly accelerator pump cams) would change it.
I finally started bumping up idle timing (while keeping the max timing of 38 constant) and the hesitation/stumble finally went away.
Mine wasn't over-complicated to sort out as I don't run vacuum advance.
