Old 08-02-2020, 02:10 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Moriarty View Post
I mentioned in another thread that I noticed some odd behavior with my amp gauge. I took a video here:
https://drive.google.com/file/d/1wVp...w?usp=drivesdk
Right at the beginning, you can see the meter goes from zero to pegged (+) directly proportional to rpm.
I've got a volt meter attached to the battery to see its charging and cut to that shortly after, but my wires weren't long enough to capture both in a single shot. Didn't see anything particularly odd there. I had put the battery on the charger for a bit before capturing this just to make sure the battery wasn't just low.
Then after turning off the engine, it occurred to me to hold the rpms for a bit to see if things settled down. However, this time when I went to test everything seemed to be working as expected.
Does this seem like a short somewhere? Voltage regulator going bad?
I guess I need to get some longer wires for the volt meter so I can see them both at the same time.
Side question: My amp gauge reads "Smith" but this is clearly just a sticker on the face. Any idea what the story is there?
EDIT: Oh.. also no longer centers on zero. I wonder if that's from pegging. I'm pretty sure it used to be properly centered, but never paid much attention. I think I would have remembered if it had been off though previously.
And yes, I should just do the volt meter modification. Before doing that, I'd like to sort out whatever else is going on to cause this.
Certainly an issue, hopefully not a partial to ground. The gauge looks faulty to me. It also does say "Smiths", but looks like a sticker.
Gary
