While I’m sure it is an excellent product that has specific places for its use where it excels, when I do some reading online on the product there are some cons to using it. While it excels in the prevention of corrosion and the lubrication of the water pump, but I would think that changing and flushing the
antifreeze every two years and using water-wetter additive should be enough for 99% of the people here. Prestone
antifreeze has a water pump lube in its mix and there are additives you can add if you like.
They talk about head temperatures being hotter to when you use waterless coolant.
I would suggest that a clean fresh coolant fluid fill, investigating the temperature range setting on the switch for your electric fans, installing earlier opening thermostat, eliminating all the air in the cooling circuit, and most of all the proper shrouds around your fans would give most people a bigger bang for the buck.
Blas
SPFWiringDiagrams@Comcast.net
