You are not going to need a large electric pump for a carb. Regardless of the pump, it would be wise to install a fuel pressure regulator and gauge on the fuel line. Holley 4150 & 4160 carbs can get a little finicky when it comes to fuel pressure. Holley recommends 5-7 psi.
Fred
Originally Posted by cobrabritt83
Looking to see what electric fuel pump I would need for my 427 s/o. The engine is build for street use and has a duel quad setup with Holley 450 carbs. I'm not sure how much flow I need i a pump or how much fuel pressure this engine requires.
