Did you remove flasher? It’s got two power in one fused for turn signals, one for flashers. If prob persists unplug steering column harness and see if fuse blows. If it doesn’t then you know prob is probably in switch or column wiring. Also grind off key switch area and fill with Bondo and go to keyless remote start/alarm unit
