Originally Posted by xb-60
Hence, present day fit would use an isolator mounted on/near the firewall, with - I think - water used from the isolator to the gauge.
Could be wrong about the water, but it would be something that obviously is not flammable
Glen
From Autometer's instructions for fuel pressure with isolator:
NOTE: Fluid leaking from system will cause gauge to read incorrectly. If leakage
occurs, fill isolator with solution of half water, half propylene glycol (
antifreeze).
