Old 08-09-2020, 07:35 PM
patrickt patrickt is offline
Originally Posted by FredG View Post
I used the Summit kit last year. It will do just fine. Install a fuel line pressure gauge. Holleys can be temperamental if the fuel pressure is not within recommended specs.
Fred
I have an in-line, liquid filled, fuel pressure gauge right there at the feed to the Holley. You have to learn how it is affected by the temperature change under the hood to really appreciate it. The first time you see it reading zero psi and your engine is running like a champ is the first lesson....
