08-11-2020, 05:57 PM
WI
Cobra Make, Engine: FFR 4071, SHP 408 Carb dry sump, G-Force T-5, 4 into 4 headers, 3-link 8.8 with 3.55 gears in the rear
If you are running mechanical gauges check to make sure they aren't bent to much. If the bend radius of the cables is too tight they will chatter and fluctuate as you described.
