Rear Ride Height Issue - Need Help
I have had a significant ride hieght issue discrepancy between the rear left and right. The shop has currently replaced the all four shocks, so all suspension measurements are within 1/2 to 3/4 inch (upper shold bolt to ground and lower shock bolt to ground on both sides). The attached pictures are after this was done.
The mechanic thinks that the body might haver flexed. But I don't necessarily think that is the case as there is no cracks or deformities in the fiberglass.
Anyone have ideas of what the problem could be?
