Thread: Headlights
  #23 (permalink)
Old 08-13-2020, 12:27 PM
cycleguy55's Avatar
Originally Posted by SBSerpent View Post
So I figured out why my City Light bulb is not working. Although it is wired on the backside of the headlamp, it's not wired back to a 12V source.
So I'm thinking that since I have a non-functional toggle switch on the dash (wired for an electric fuel pump which I do not have), I can utilize that switch for turning on/off the City Lights on the Hella headlight. Just have to put the toggle switch in line with the supply wire to the little bulbs. But first I need to confirm that the two wires currently attached to the switch are fused (i.e. connected to the fuse box where the E. Pump fuse is located...if there is a fuse there).
Any glaring flaws to my thoughts on this?
I don't see any 'glaring flaws' - but have you thought about wiring them to the parking / running lights circuit? Alternatively you could set them up as DRLs, either with a DRL module or a relay that powers them up when the ignition is on.
Brian
