  #31 (permalink)
Old 08-14-2020, 03:10 PM
eschaider's Avatar
Originally Posted by Michael C Henry View Post
... It is or was a 15"OD steering wheel so now I'm looking for 15" OD steering wheel with no off set, six bolt pattern with no off set, horn button or emblem center. A Cobra center emblem would be a find. ...
Mike, you can easily make one of the Cobra steering column top rings to match a 70 or 75mm bolt circle. Bore the center hole to match the original Cobra center holes. The finished piece will look like this;
Replace the horn ring / center button with your newly fabricated top ring.
Next step, go to Finishline, Branda or any number of other providers and get a center cap for the original top ring (which your manufactured one duplicates the center hole dimensins of).
This is what the Cobra cap looks like from Finishline;
Push it into the center hole of your new top ring and you are done. Voila!
If you like the AC center cap then buy this one from the same guys;
Ed
