Originally Posted by trcunni
Looking for mounting hardware for the rear shocks. Specifically, the double end threaded steel rod that the top and bottom of the shock bolts onto. There are four. The rods are 9" long, 7/16 threads on both ends, with a 0.620" diameter shoulder. Anybody have some of these laying around?
I used these: Jaguar IRS Shock Mounting Studs #91645318 bought from Speedway Motors
https://www.speedwaymotors.com/Jagua...Query=91645318
However, they are 8-3/4” overall length and you mention 9” so beware they may not meet your needs. The other dimensions you noted seem a likely match. You did mention a 0.620” shoulder, I believe these are 0.625”, yet may actually be the same intended dimension.
You asked if anyone has any laying around. While I may still be able to dig up my old one’s and would gladly give you if I didn't toss them, they were about ¼”shorter than the ones above, to the point the threads didn’t exit the nut fully, and they were chewed up, so likely not a viable option for you anyway.
Best of luck…Brent
