Old 08-20-2020, 05:28 AM
joyridin''s Avatar
joyridin' joyridin' is offline
Larger pistons are going to make the situation worse. If you want to increase braking to the rear in an attempt to initiate lock-up, you will need to use smaller pistons in the calipers. The MC will put more pressure on the rear causing them to react faster. I have .750" diameter master for the front and .625" on the rear with Jaguar calipers.
