Old 08-22-2020, 06:51 AM
classical glass classical glass is offline
Default Front brake caliper pressure
Hi, I have a ERA 427 and my brakes just aren't what they should be. I installed a new Master cylinder and checked the line pressure. I'm getting aprox 760 lbs at the caliper. Is that normal? I bled and flushed the system several times and I'm using Dot 4 brake fluid the pedal is hard and positively no air in the line. Does all this make sense?
Thanks
