Old 08-22-2020, 03:08 PM
RockBit's Avatar
RockBit RockBit is offline
Cobra Make, Engine: ERA #812 427/482 FE
You need to make sure your valve cover is baffled under the PVC valve. If it is not, that explains the higher oil consumption. You may also want to install an oil catch can between the PVC valve and the port.
I would just tee off the line going into the 3/8 port for the PVC and the power brake booster.
Chris
