Old 08-25-2020, 07:45 AM
Chicagowil's Avatar
Chicagowil Chicagowil is offline
Originally Posted by rads42 View Post
Rookie question here as I know very little about fuel injection. Where does the O2 sensor go on a cobra with side pipes? I was looking at the instructions online for the Pro-flo 4 and it wants it past the collector. So there'd only be the little space between the muffler and collector and I assume you'd want that as hidden as possible so it would have to be between the body and the exhaust pipe. Seems like a pretty small space.
The O2 sensor needs to be just after the junction of the header pipes. On my CR 1 it is located just before the muffler. But CR di make one mistake- they have it angling up instead of down. This will cause it to collect moisture and over time destroy the O2 sensor. But they did it to conceal it and fit it under the edge of the body. Still not right. But on a low use and fair weather car- not as critical.
I had looked at this same system for my car as well. The CR1 has the 5.0 mounted pretty high up in the engine compartment. As I was using a Kenne Bell supercharger- there was no way to fit it under the stock hood. But at a package price of about $2,500.00, I decided to modify the hood to clear the S/C. Since I already had the S/C which adds over 100hp, I modified the hood. But I thought the system was the best of the retrofit EFI systems that will give you the "original look" of a carb with the tuning of EFI. It does, as was mentioned here, have limits of performance to more highly modified motors without custom tuning.
The next best but considerably more expensive choice is the Weber style EFI systems. But at over $4k and much taller, it causes one pause.
Thom
