Old 08-27-2020, 06:50 AM
strictlypersonl strictlypersonl is offline
I'm going to repeat and emphasize Dan's post.
"If you have high pedal pressure and excessive travel then you have problems - because to lessen the pressure you will need to go to a smaller diameter master cylinder that will lengthen the travel further. Or to lessen the travel you can go to a larger master cylinder which will increase the pedal pressure even more. That's the trade offs in a master cylinder/slave cylinder system. Maybe it's the pedal set up. Can you identify the pedal set up or take a picture and some dimensions of the arm dimensions and dimensions to the rod attachment points?"
