Originally Posted by cycleguy55
Yes, that's the way an automatic choke operates. It will be fully open from when it was last run - the heating element in the choke pulls it open. After it's shut off the bimetallic coil cools and applies spring tension to the choke mechanism. The first touch of throttle will release the spring tension and pull the choke plate closed tight. Once it's started engine vacuum will pull the choke open to the set point of the choke pull-off mechanism. After that the bimetallic coil will continue heating while the ignition is on, allowing the choke plate to open further and further until fully open. There's also an interaction with the fast idle cam to keep the idle speed higher until the engine is warmed up.
More here: https://forums.holley.com/entry.php?...rel-Carburetor
This article has good instructions on adjusting carbs. It shows a pull-off adjustment you won't find on Holley's official pages - it's the adjustment I used on mine to make it run properly.
https://www.chevelles.com/threads/ad...#post-11389045
Thank you greatly. I'll be checking these out tonight. Appreciate the info on why the flaps are open at shutdown.
