Originally Posted by patrickt
Most thieves can't drive a stick anymore. If you have a MSD unit, the box is wired to enable a "kill switch" with the existing wiring. Mucho simple. And if you really want to discourage someone from driving off with your car, get a quick release hub and take the steering wheel with you.
Nothing that I can see in my instructions that specifically identify a switch other than the ignition switch. The only logical place to connect a switch would be in the circuit from the ignition switch (small red wire). Cut that and route it through the kill switch to kill the MSD input from the ignition switch.
Best place to install the switch? Under the hood? Under the dash?
