Originally Posted by rads42
I do have the square plug, I was asking about the gasket because while I have the fluid drained I wanted to pull the cover for inspection.
Jaguar differentials have a casting number at the lower right corner of the cover. All of the gaskets that I've seen for those type diffs had a 3931 number and then sometimes letters after the part number depending on where you bought the gasket from. But if the fluid comes out looking not metallic-ish, I wouldn't pull the cover off. It's not like you can wiggle something and tell that it's loose. If you have a problem back there, you're going to feel/hear it.
