  #25 (permalink)
Old 09-05-2020, 11:49 AM
eschaider's Avatar
Originally Posted by incoming View Post
I have experience with both Lexan and Poly windshields. I ride a Harley FXRT and need taller than stock windshields. Have had it many years. I also work in the commercial kitchen equipment industry and have a lot of sneeze guards and such custom cut and bent.
I personally wouldn't use either unless absolutely necessary for a car unless she's a trailer queen.
Through experience on long rides, my windshield comes off with a couple of screws and goes into the bathtub at the motel to soak to remove bugs.
Poly is a little better but not much.
I do use a silicone based stuff given to me to clean my windshields. Looks like old school Armor All. Supposed to make stuff not stick to it.
Is there a hidden reason you are cracking windshields?
The windscreen frame is a soft aluminum, I believe, and quite flexible. Some of the screws used to attach or hold things together, I suspect but don't know with certainty, abrade against the edge of the glass producing a fracture point much like scribing a line on a glass pane with a glass cutting scribe. Sooner or later a bump in the road pushes the windshield against the offending fastener once to often and you have a cracked windshield.
Ed
