I'm throwing the towel. When I tap into the red wire I expected to have power with the ignition switch turned on. No such luck. I simply cannot figure out which wire feeds the brake light switch. I could go find the switch on the master cylinder but I just don't feel like putting anymore time into this project. If the car doesn't pass the NY safety inspection I will go with either Patrick's home remedy but truthfully being diode challenged will probably get Bob's plug and play harness to make a permanent 4 way flasher system.
Thanks Kevin and Patrick for your replies.
Gary
