NAPA will do custom spray cans if you can give them the code or mix #'s. You can make a pinhole mask to touch up chips and such. This may give you a better chance of matching the metallic lay. Otherwise metallic touch ups will tend to be dark spots when applied by touch method
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
