SCOF, in a nutshell, has always been thick on banter but an outstanding source for R&R on a Superformance. You just have to filter through all the noise.
Adding to the OP and other comments, you can find an SPF in the $40K range but they are all older builds (pre 2000) and you can expect to have to perform various needed upgrades and/or the engines have some mileage on them. With an worn FE expect at minimum $55-60K (cars with FEs always command higher resale values...it's just a plain fact). Deals are always out there but the final cost is usually a "you get what you pay for" endpoint. Good luck!
