Originally Posted by olddog
Are these heads cut off short in the intake ports and the missing parts cast into the intake like all FE engines? The pictures make it look more like most other engine designs where the intake does not have part of the valve cover rails cast into the intake.
The intake is similar to a tunnel port look only the ports are between the valves and does not have a push rod in the center of the port.
Any light you can shed would be appreciated.
The bottom photo shows a front on shot, where you can see the intake has the valve cover rails.
