09-17-2020, 08:38 AM
CA
Cobra Make, Engine: BDR build #983, FRM 392
Originally Posted by cycleguy55
If you don't already have them, give serious consideration to installing a set of oil pan reinforcement rails. They'll stop the deformation of the sheet metal on the pan rails that lead to leaks. They're available from a wide variety of sources:
In addition to the reinforcement rails, I also replaced the oil pan bolts with studs and 'flange nuts'. Others may disagree, but IMO the pan is easier to install that way, plus the flange nuts have one way 'teeth' where they meet the pan rails to help prevent loosening.
Can these reinforcement rails be used on pans that have the recesses in the rail or are they designed solely for use on pans with smooth rails???
