Or put in some fresh gas with carb cleaner and use the start button. Let it warm up and change the
oil and coolant.
If you change fluids before you start it then you're leaving behind suspended stuff in the pan that has settled and just goes back when you run it. At a minimum you need to change it again immediately. So just start it.
If it doesn't start then clean the carb.
