pin and roll pin along with finger{not the correct term} were brand new not bent. yes I have looked at dozens of videos called tremec sent to silver sport they are working on a fix Meanwhile stuck using the pins from tremec. I am looking to upgrade to a magnum but it seems to be to long to fit in a backdraft. Motor is moved back in these cars for better handling. Not sure what it would take to install just want to keep the tko its lighter and smaller. Gears are plenty strong just the pin is the problem.Don"t know why paul is not a fan it has larger gears than a top loader just the pin should be a easy fix. Also it is a five speed whats not to like again other than the pin?
