09-24-2020, 03:11 PM
CA
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Originally Posted by cycleguy55
Those standard split pins are very weak compared to coiled pins. Spirol (and others) also have a heavy duty version you may want to look at for additional strength and avoid pin breakage. For example, the standard 5/16" Spirol pin has a Minimum Double Shear Strength of 5,500 lbs, while the same size heavy duty pin is rated for 7,800 lbs. I suspect both of those are considerably higher than standard split pins.
https://www.spirol.com/company/produ...od_d.php?ID=50
sorry not the roll pin the shift rail is what is cracking into two pieces
