Original leaf spring and coil spring cars had leather straps attached to opening lever and mounted at the other end under the upper door frame tube. I use the strap to hold the lever open and pull the door closed by the upper door frame tube and release the strap when door is closed. Or just pull it shut from the upper door frame tube. Not a big deal.
