Old 09-27-2020, 08:29 AM
powrby4d powrby4d is offline
Cobra Make, Engine: Shell Valley 428CJ with 427 Tunnel Port top side
Thanks. After further investigation I can see that there is no adjustment on the frame side of the hinge as it’s a pin that fits in a bracket welded to the frame, so I’ll see if I can make the minor adjustment to the doors. It seems the easiest thing to do would be to just close the door and loosen the bolts, hold the door tight and retighten the bolts so that it aligns better,because the fit is very close when it’s closed, possibly just a tiny bit low since the pressure has worn off the weatherstripping.
