Originally Posted by Danr55
Interesting finding on my car. Excessive fuel had washed the oil off of the cylinder walls and worn the rings to nothing. Motor was using about 1 qt. every 300 miles. Be careful to run the right size carb or you could be right back in the same spot in short order.
XP 750 always lean, idle screws 7/8-1 turn, small jets, annular boosters, no choke...
Understand the damage rich mixture can do to the cylinders...
Thanks
Steve H
SP 1764
