Old 10-02-2020, 01:57 PM
cycleguy55's Avatar
Originally Posted by Busamike View Post
My bad, it is the bearing dust or grease cap that the wheel has the problem clearing.
Would I be correct in assuming you're talking about the hub centre bore diameter, or are you referring to the distance the grease cap protrudes out from the hub surface?
If it's the former, there are absolutely zero issues:
Brian
