Old 10-06-2020, 06:32 PM
patrickt patrickt is offline
Originally Posted by davids2toys View Post
. 12v light? Are we still talking about a test light, or something like this...
That light would be perfect. And the way you strip a wire in mid-span is with a razor blade. You just lightly shave the plastic insulation off just like you were whittling a stick with a pocket knife. You should practice first on a regular piece of insulated wire while you sit in front of the TV. Just take your razor and slice about an inch of plastic insulation off without sticking the razor in so hard that you break one of the copper strands. If you practice a couple of times you'll end up saying "Dang, this is actually pretty easy." And then when the tests are over, you just wrap black electrician's tape around the spot that you shave off. Nothing to it.
EDIT -- And you shave the plastic off all around the wire so there's a nice 360 degree gap of plastic insulation. That makes it really easy to wrap your mid-span tap around that gap for a nice connection. And if for some reason you wanted to make it permanent (which you don't for this test) then you would just melt a little solder on it and you've got a nice, permanent soldered tap.
