Originally Posted by davids2toys
That sounds like the way I have it hooked up. Is that the way you have yours setup also? I know MSD does not like it that way!
Does that CB ever blow or wear out leading to malfunction? Is that an item I should carry in the emergency car repair kit in the trunk
That's the way I have mine and the circuit breaker has never blinked in 15 years. Remember, having the MSD box's feed on the alternator side of the circuit breaker (the protected side) means that most of the current going in to the MSD box will not be going through that circuit breaker anyway, it will be fed from the alternator to the box, not the battery.
