  #34 (permalink)
Old 10-08-2020, 08:14 AM
tboneheller's Avatar
tboneheller tboneheller is offline
Cobra Make, Engine: E.R.A. #505
I had a problem with mine shutting off. It ended up being a large brown wire ( I think that was the color) had burnt in the multi pin connector that was inside the cockpit behind the center area of the dash. I think it supplied power to the AMP gauge or from the AMP gauge. It took me a few wrecker bills to find it because after the car sat for awhile until I could try to diagnose the problem, the car would start. Check that first. It was a CLEAR CONNECTOR that was in-line. Most likely the dash harness connector. This occurred about 18 years ago. My car is ERA505. Hope this helps.
