10-08-2020, 10:34 AM
ct
Cobra Make, Engine: ERA, 428, 4 speed Toploader, Jag rear, Red with White stripes
Originally Posted by tboneheller
I had a problem with mine shutting off. It ended up being a large brown wire ( I think that was the color) had burnt in the multi pin connector that was inside the cockpit behind the center area of the dash. I think it supplied power to the AMP gauge or from the AMP gauge. It took me a few wrecker bills to find it because after the car sat for awhile until I could try to diagnose the problem, the car would start. Check that first. It was a CLEAR CONNECTOR that was in-line. Most likely the dash harness connector. This occurred about 18 years ago. My car is ERA505. Hope this helps.
You are saying the car would still start?
ERA#698 428, 4 speed Toploader, 3:31 Jag rear
