Old 10-11-2020, 06:46 AM
joyridin''s Avatar
joyridin' joyridin' is offline
I do not see what is stabilizing the bottom of the steering column. Normally, there is a bearing there or a spring set-up to stop the shaft from moving around in the column. Yours just seems to end. The set-up you have is similar to mine, but mine has a column support and a spring before the first joint.
