  #21 (permalink)
Old 10-11-2020, 04:34 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Also be sure the 2 mounting tabs are in good condition. They can be replaced if you have a good welding shop when off the car. I notice a distinct line on the 4to1 adapter that would not be noticed on ceramic coated pipes. Could just be the weld line and paint burning off because of the thermal interruption of the weld between parts. Same on rear turn-out.
You both should share your Engine’s head info upfront. Someone here could tell you if the flanges will fit your cars engine easily....
Blas
SPFWiringDiagrams@Comcast.net
