Old 10-20-2020, 04:35 PM
1795's Avatar
1795 1795 is offline
It's also possible, if this has not happened before, that the misalignment fits the wheel only when the holes in the wheel are in a specific alignment with the pins. Try rotating the wheel on the hub and trying different wheel alignments.
It could also be a buildup of never seize on the pins, or in the holes in the wheel as well. Clean both thoroughly and see if that helps.
